Taco has introduced new, compact HS Series Horizontal Split Case Pumps, which take up 50% less floor space while offering the same superior hydraulic performance. Precisi...
Taco’s new SmartPlug™ will optimize hot water system efficiency and reduce electrical consumption up to 94% while saving 12,000 gallons of water per year.
The device adds intelligence to standard on/off hot water recirculation (HWR) pumps. Rather than plugging the standard HWR into the wall, plug it into the SmartPlug for improved, house/family-specific function.
In the “Smart” mode, the SmartPlug monitors and records weekly household hot water use patterns and adjusts HWR cycles accordingly. That way, hot water is provided quickly at all fixtures, only when needed.
The device offers an optional “Pulse” mode. In this setting, the circulator will cycle on and off to maintain hot water at all fixtures. No more waiting, no more wasting energy and water.
Users get even greater efficiency with the SmartPlug system. After 36 hours of inactivity, the device automatically turns off the pump until a need for hot water is detected; in this mode, it also cycles on once every seven days for 10 seconds to prevent corrosion or scale buildup.
SmartPlug can be used with any Taco domestic water 00® circulator with a 110 Volt line cord. No programming is required.
Navien, a leading manufacturer of high-efficiency comfort solutions, has announced the launch of its new NAA Series air conditioner, further strengthening the company’s r...
Merino Energy, a San Francisco-based climate hardware company built to make buying and installing a heat pump as efficient as the technology itself, today emerged from st...
