Rapid Locking System (RLS), the leading provider of press-to-connect fittings and the HVAC/R industry’s most trusted brand, announced the arrival of the new RLS Powered b...
Webstone®, a brand of NIBCO, announces an expansion to its line of transition products including Press × PEX reducing fittings, baseboard elbow, and dual-vent elbow for use with the 1/8” NPT vent of your choice. The innovative, patent-pending dual-vent design ensures that an upright vent port is accessible no matter which orientation the elbow is installed. Ideal for boiler risers or baseboard radiator installations, each elbow includes a brass stiffener for copper finned tube press connections. All products are certified lead free and available for F1960 or F1807 PEX.
Learn more: www.webstonevalves.com/PEX
SFA SANIFLO USA, a division of Group SFA and a leading global manufacturer of above-the-floor macerators, grinders, drain pumps, lift stations, and condensate pumps, has ...
U.S. Boiler Company introduces its ALTA OneVent System, a simple and safe solution that enables common venting of up to four ALTA high-efficiency boilers. Designed to exp...
