Taco has introduced new, compact HS Series Horizontal Split Case Pumps, which take up 50% less floor space while offering the same superior hydraulic performance. Precisi...
Watts has announced the launch of its new QuadRail™ Fastener system. The QuadRail™ Fastener is designed to hold a wide variety of Watts tubing and pipe in a substrate such as concrete, thin slab, and sand.
Ideal for radiant heating/cooling or snow melt applications, these rails can be secured to foam board insulation, wood sub-flooring, or turf using staples, screws, or nails.
The QuadRail™ Fastener can be used with the following Watts tubing:
Fastener specifications:
For more information, go to Watts.com.
Navien, a leading manufacturer of high-efficiency comfort solutions, has announced the launch of its new NAA Series air conditioner, further strengthening the company’s r...
Merino Energy, a San Francisco-based climate hardware company built to make buying and installing a heat pump as efficient as the technology itself, today emerged from st...
