1927 Proposal for a Mouat Vapor Heating System
Download pdf (3.9 MB)
Thanks to Gerry Gill for sharing this Mouat Vapor Heating System proposal from the early days of steam heating. Note the nine-ounce setting on the relief valve. You don't need high pressure to heat a building.
O-E Vapor System Manual
This manual was created by O-E Specialty Manufacturing Co. and outlines how to install the "O-E" Perfect System, which is a Vapor Vacuum heating system.
Published on 01/12/2026 11:38 AM
Posted in Heating Museum
