The Improved Webster Type "R" System of Steam Heating is a service bulletin from Warren Webster and Company (The Pioneers of Vacuum Steam Heating), established in 1888.
A Proposal for Warming Rooms by the Steam of Boiling Water Conveyed in Pipes Along the Walls
This document is subtitled "And also a Method of Preventing Ships from Leaking" and was written by Col. Wm. Cook. This original document is from The Philosophical Transactions of the Royal Society of London, 1745. This is the first time the possibility of heating buildings with steam is mentioned in a book.
Comments by Vanilla
The Improved Webster Type "R" System of Steam Heating - Service Bulletin (1932)
O-E Vapor System Manual
This manual was created by O-E Specialty Manufacturing Co. and outlines how to install the "O-E" Perfect System, which is a Vapor Vacuum heating system.
H.B. Smith Company Oil Fired Cast Iron Hot Water Boilers (1972)
Here is the original Installation and Operating Instructions and Parts List for The H.B. Smith Company's Oil Fired Cast Iron Hot Water Boilers (No. OHB-13W). This is esti...
