This manual was created by O-E Specialty Manufacturing Co. and outlines how to install the "O-E" Perfect System, which is a Vapor Vacuum heating system.
Amstan Wet Heat and Cooling Products (1957) - Part 1
Here is a catalog from Amstan (American Standard), published in 1957, that features their wet heat and cooling products. This document is divided into 5 parts. Many of the products you'll find here are still in the field.
Thanks to John Mills for sharing and scanning this catalog. And thanks to Alex Marx for his help with the file conversions.
Comments by Vanilla
O-E Vapor System Manual
H.B. Smith Company Oil Fired Cast Iron Hot Water Boilers (1972)
Here is the original Installation and Operating Instructions and Parts List for The H.B. Smith Company's Oil Fired Cast Iron Hot Water Boilers (No. OHB-13W). This is esti...
Heating the Henry Ford Museum
The Henry Ford Museum in Dearborn, MI has an interesting hot-water heating system. Take a look at the radiators below. They are from the Shaw-Perkins Manufacturing Compan...
