Amstan Wet Heat and Cooling Products (1957) - Part 2
Download pdf (7.2 MB)
Here is a catalog from Amstan (American Standard), published in 1957, that features their wet heat and cooling products. This document is divided into 5 parts. Many of the products you'll find here are still in the field.
Thanks to John Mills for sharing and scanning this catalog. And thanks to Alex Marx for his help with the file conversions.
O-E Vapor System Manual
This manual was created by O-E Specialty Manufacturing Co. and outlines how to install the "O-E" Perfect System, which is a Vapor Vacuum heating system.
Published on 01/12/2026 11:38 AM
Posted in Heating Museum
Heating the Henry Ford Museum
The Henry Ford Museum in Dearborn, MI has an interesting hot-water heating system. Take a look at the radiators below. They are from the Shaw-Perkins Manufacturing Compan...
Published on 03/07/2025 2:09 PM
