In this presentation, Gary Klein shares important information about air source heat pump water heaters (HPWH), with particular attention paid to where the warm air comes ...
Boiler Room Detective Webinar
During this entertaining and informative one-hour webinar, you will be a famous detective uncovering clues about boiler operation, efficiency, and safety. Industry expert Ray Wohlfarth will help you solve the following mysteries:
- How to be sure the boiler room is safe Can the boiler breathe?
- What boiler noises should raise a red flag?
- How a tissue can help diagnose system problems
- What’s stored in the boiler room and is it dangerous?
- What does rust on top of the water heater mean?
- Why is carbon monoxide dangerous?
- How does combustion air affect boiler operation?
- What is the leading cause of boiler accidents?
- What pressure should we see on the boiler pressure gauge?
- What does a discolored boiler jacket indicate?
Would you like to learn more from Ray? Check out his seminars and books.
Comments by Vanilla
Air Source Heat Pump Water Heaters
Classic Hydronics Seminar
In this all-technical three-hour seminar, Dan Holohan will give you a Liberal Arts education in those Classic Hydronics systems. He’ll have you seeing inside the pipes as...
