In this presentation, Gary Klein shares important information about air source heat pump water heaters (HPWH), with particular attention paid to where the warm air comes ...
Classic Hydronics Seminar
In this all-technical three-hour seminar, Dan Holohan will give you a Liberal Arts education in those Classic Hydronics systems. He’ll have you seeing inside the pipes as he gives you a better understanding of how things work, what goes wrong with them, and why. He’ll share with you the secrets he’s picked up from the Old-Timers and he’ll make you a better troubleshooter.
We'll look closely at:
- The critical importance of pressure differential
- Gravity hot water heating
- Pumping
- Radiation
- One-pipe loops
- One-pipe primary-secondary systems
- Diverter tees
- Two-pipe direct- and reverse-return
- Two-pipe primary-secondary
- Multiple boiler systems
- Two-temperature systems
- Air problems and their solutions (once and for all)
- Classic radiant
And more!
Comments by Vanilla
Air Source Heat Pump Water Heaters
Do Radiator Reflectors Work?
Circulators or Zone Valves
