This manual was created by O-E Specialty Manufacturing Co. and outlines how to install the "O-E" Perfect System, which is a Vapor Vacuum heating system.
Dunham General Products Bulletin of Low-Pressure Steam Heating Appliances
This brochure outlines Dunham's product offering in 1946. It outlines how the Dunham Differential Vacuum Heating System worked. It also highlights products including Dunham differential control equipment, float and thermostatic traps, bucket traps, return traps, vacuum pumps, condensation pumps, unit heaters, convectors, fittings, pressure reducing valves, and air eliminators. There is a very good engineering section near the end of the booklet.
Here is the original Installation and Operating Instructions and Parts List for The H.B. Smith Company's Oil Fired Cast Iron Hot Water Boilers (No. OHB-13W). This is esti...
The Henry Ford Museum in Dearborn, MI has an interesting hot-water heating system. Take a look at the radiators below. They are from the Shaw-Perkins Manufacturing Compan...
