This manual was created by O-E Specialty Manufacturing Co. and outlines how to install the "O-E" Perfect System, which is a Vapor Vacuum heating system.
Elements of Industrial Heating (1922)
Elements of Industrial Heating was published in 1922. "The purpose of this booklet is to draw attention to essential factors governing the quality and cost of products subjected to the action of heat in the process of manufacture, and the selection and use of equipment, fuel or electricity necessary to produce better results at lower cost." To access this book online, click here.
Comments by Vanilla
O-E Vapor System Manual
H.B. Smith Company Oil Fired Cast Iron Hot Water Boilers (1972)
Here is the original Installation and Operating Instructions and Parts List for The H.B. Smith Company's Oil Fired Cast Iron Hot Water Boilers (No. OHB-13W). This is esti...
Heating the Henry Ford Museum
The Henry Ford Museum in Dearborn, MI has an interesting hot-water heating system. Take a look at the radiators below. They are from the Shaw-Perkins Manufacturing Compan...
