In this presentation, Gary Klein shares important information about air source heat pump water heaters (HPWH), with particular attention paid to where the warm air comes ...
Heat Exchangers in Plumbing and Hydronic Systems
HeatingHelp.com partnered with Caleffi on this Hot Topics with Hot Rod webinar. In this episode, Hot Rod takes a closer look at heat exchangers and answers these questions: What is a heat exchanger? What are the pros and cons of various types of heat exchangers? How do you size and install a heat exchanger? How do you service and troubleshoot heat exchanger problems?
Comments by Vanilla
Air Source Heat Pump Water Heaters
Classic Hydronics Seminar
In this all-technical three-hour seminar, Dan Holohan will give you a Liberal Arts education in those Classic Hydronics systems. He’ll have you seeing inside the pipes as...
Do Radiator Reflectors Work?
