In this presentation, Gary Klein shares important information about air source heat pump water heaters (HPWH), with particular attention paid to where the warm air comes ...
How Gravity Hot-Water Heating Systems Work
In this video, Dan Holohan teaches us about gravity hot-water heating systems. Classic gravity heating is both the simplest and the most complicated system of all. It’s simple because it has few moving parts. The water is the only true moving part. Hot water rises; cold water sinks; it’s that simple. But at the same time, it’s complicated because the pipes have to be just the right size for the amount of water that’s flowing, and they have to have the perfect pitch. The fitter has to make sure to remove the burrs from the pipes he cuts, otherwise there could be too much friction presented to the flow.
Want to learn more? Read Dan Holohan’s book Classic Hydronics: How to Get the Most From Those Older Hot-Water Heating Systems.
In this all-technical three-hour seminar, Dan Holohan will give you a Liberal Arts education in those Classic Hydronics systems. He’ll have you seeing inside the pipes as...
