Light, Heat and Power in Buildings (1901)
Light, Heat and Power in Buildings was written by Alton Dermot Adams and published in 1901. "In this volume the object is to present in compact form the main facts on which slection of the sources for light, heat and power in buildings should be based." To access this book online, click here.
O-E Vapor System Manual
This manual was created by O-E Specialty Manufacturing Co. and outlines how to install the "O-E" Perfect System, which is a Vapor Vacuum heating system.
Published on 01/12/2026 11:38 AM
Posted in Heating Museum
Heating the Henry Ford Museum
The Henry Ford Museum in Dearborn, MI has an interesting hot-water heating system. Take a look at the radiators below. They are from the Shaw-Perkins Manufacturing Compan...
Published on 03/07/2025 2:09 PM
