Mark C. Honeywell's Patent for the Heat Generator
Download pdf (1.9 MB)
By using a pot of mercury and a submerged pipe, this device separated the water in the system from the water in the expansion tank. Honeywell called it the Heat Generator and it allowed open hot water systems to operate under pressure, and at higher temperatures, but still remain safe. This was a major advance in hot-water heating in that it allowed the hot-water people to compete with the steam people, whose prices were usually less. The patent dates to October 22, 1907. Thanks to Gerry Gill for sharing this with us.
O-E Vapor System Manual
This manual was created by O-E Specialty Manufacturing Co. and outlines how to install the "O-E" Perfect System, which is a Vapor Vacuum heating system.
Published on 01/12/2026 11:38 AM
Posted in Heating Museum
Heating the Henry Ford Museum
The Henry Ford Museum in Dearborn, MI has an interesting hot-water heating system. Take a look at the radiators below. They are from the Shaw-Perkins Manufacturing Compan...
Published on 03/07/2025 2:09 PM
