In this presentation, Gary Klein shares important information about air source heat pump water heaters (HPWH), with particular attention paid to where the warm air comes ...
Primary-Secondary Pumping on a One-Pipe Hot Water Heating System
In this excerpt from his Classic Hydronics seminar, Dan Holohan explains how primary-secondary pumping works in a one-pipe hot water heating system. Dan talks about valves, circulators, flow rate, pressure drop, blending temperatures, and more.
Want to learn more? Read Dan Holohan’s book Classic Hydronics: How to Get the Most From Those Older Hot-Water Heating Systems.
          Comments by Vanilla
      Air Source Heat Pump Water Heaters
      Classic Hydronics Seminar
In this all-technical three-hour seminar, Dan Holohan will give you a Liberal Arts education in those Classic Hydronics systems. He’ll have you seeing inside the pipes as...
      Do Radiator Reflectors Work?
