Radiant Heat with Copper Tubing - A Practical Research Program
Download pdf (4 MB)
This document contains a series of interesting articles by Mills and LaTart of Revere Copper and Brass about radiant heat with copper tubing. It is not dated, but is most likely from the late-1940s. Thanks to Jim Walls for finding and scanning this one.
O-E Vapor System Manual
This manual was created by O-E Specialty Manufacturing Co. and outlines how to install the "O-E" Perfect System, which is a Vapor Vacuum heating system.
Published on 01/12/2026 11:38 AM
Posted in Heating Museum
Heating the Henry Ford Museum
The Henry Ford Museum in Dearborn, MI has an interesting hot-water heating system. Take a look at the radiators below. They are from the Shaw-Perkins Manufacturing Compan...
Published on 03/07/2025 2:09 PM
