Radiant Heating for The Modern Home
Download pdf (3.3 MB)
This circa-1947 brochure from Kohler makes a great case for hydronic heat. The "radiant" they refer to in the title isn't floor-heating, but cast-iron wall radiators.
O-E Vapor System Manual
This manual was created by O-E Specialty Manufacturing Co. and outlines how to install the "O-E" Perfect System, which is a Vapor Vacuum heating system.
Published on 01/12/2026 11:38 AM
Posted in Heating Museum
Heating the Henry Ford Museum
The Henry Ford Museum in Dearborn, MI has an interesting hot-water heating system. Take a look at the radiators below. They are from the Shaw-Perkins Manufacturing Compan...
Published on 03/07/2025 2:09 PM
