This manual was created by O-E Specialty Manufacturing Co. and outlines how to install the "O-E" Perfect System, which is a Vapor Vacuum heating system.
The Dunham Packless Inlet Valve
Packless radiator supply valves kept air from working its way into a vacuum system. This bulletin from C.A. Dunham Co. is from 1916 and features the Dunham Packless Inlet Valve. Thanks to David Cordes for sharing.
Comments by Vanilla
O-E Vapor System Manual
H.B. Smith Company Oil Fired Cast Iron Hot Water Boilers (1972)
Here is the original Installation and Operating Instructions and Parts List for The H.B. Smith Company's Oil Fired Cast Iron Hot Water Boilers (No. OHB-13W). This is esti...
Heating the Henry Ford Museum
The Henry Ford Museum in Dearborn, MI has an interesting hot-water heating system. Take a look at the radiators below. They are from the Shaw-Perkins Manufacturing Compan...
