This manual was created by O-E Specialty Manufacturing Co. and outlines how to install the "O-E" Perfect System, which is a Vapor Vacuum heating system.
The Problem Solver Hydronic Heating Handbook (August 1984)
This August 1984 issue of The Problem Solver Hydronic Heating Handbook by Wallace Eannace Associates, Inc. is about heating system noises. It covers velocity noise, noisy pump bearings, pipe expansion noises, misalignment, reverse pump rotation, trapped air in a pump body, cavitation, not enough pressure at the top floor, chattering flow valves, as well as chattering pressure-reducing valves.
Comments by Vanilla
O-E Vapor System Manual
H.B. Smith Company Oil Fired Cast Iron Hot Water Boilers (1972)
Here is the original Installation and Operating Instructions and Parts List for The H.B. Smith Company's Oil Fired Cast Iron Hot Water Boilers (No. OHB-13W). This is esti...
Heating the Henry Ford Museum
The Henry Ford Museum in Dearborn, MI has an interesting hot-water heating system. Take a look at the radiators below. They are from the Shaw-Perkins Manufacturing Compan...
