Taku Plumbing and Heating LLC
PO Box 240940, Douglas, AK 99824
Contact: Eugene Vick
Phone: (907) 419-5453
Website: https://www.takuplumbingheating.com
Share this business
Profile
Local plumbing business in Douglas, Alaska.
Services
Leaks, clogs, remodels, boiler maintenance, & boiler installs.
Case Study
no heat
Challenge
boiler not firing off unless you tapped the aquastat.
Approach
Checked L1 & L2 voltage coming in. Good voltage. Pressed the relay. It would stick but hesitantly.
Solution
Replaced the aquastat. Boiler fired off, no problem.
