Navien, Inc. proudly announces the availability of its highly anticipated NWP500 Series Heat Pump Water Heater. This next-generation, eco-friendly water heating solution ...
Armstrong Fluid Technology has unveiled a new high performance Pressurizing Pump for the Latin American residential market that is designed to increase hydraulic pressure in homes that have dishwashers, high-flow showerheads, water heaters and other high-demand equipment.
Featuring low power consumption and a flow sensor that allows automatic activation, the new Armstrong Pressurizing Pump can supply a home with 1 to 5 bathrooms. It can be installed at the outlet of a water tank or before any supply or derivation to service.
Adaptable to both cold and hot water up to 90°C, the new pump is ideal for instantaneous heaters. It can also be used for ventilation, heating and air conditioning circulation.
The pump activates automatically when a tap is opened and turns off when the tap is closed.
Quilt, the smartest and most efficient two-zone heat pump on the market, is launching two powerful new features just in time for summer — Auto-Away and Energy Usage — mak...
