Quilt today announced it has reached 100 Quilt Certified Partners across 26 U.S. states and six Canadian provinces in under one year since launching its Certified Partner...
Ferrous oxide debris, which is abrasive and often microscopic, is created from the oxidation of iron or steel materials. It can deposit onto heat exchanger surfaces and accumulate in other components including circulators, causing reduced thermal efficiency and premature equipment wear.
The new ASME registered NA546M Series DISCALDIRTMAG® continuously and efficiently removes air and debris that forms in hydronic circuits including the removal of up to 100% of ferrous debris. Non-ferrous debris gets separated out by colliding with an internal element in the flow stream and settling to the bottom of the separator, while the microscopic ferrous debris gets drawn into and captured by a concentrated magnetic field created from a stack of powerful neodymium rare-earth magnets located beneath the flow stream. A blow down ball valve allows easy removal of all captured debris.
CALEFFI – Creating innovative, superior performance products that help customers live comfortably and economically, while softening their impact on the environment. For more information, visit Caleffi’s Web site at www.caleffi.com, email, or call (414) 238-2360.
Rinnai America Corporation, a leading North American manufacturer of innovative, energy‑efficient tankless water heaters, today announced its REHP Series Electric Heat Pu...
New Taco Thermal Energy Storage (TES) tanks play a critical role in shifting energy loads, improving hydronic system efficiency, and helping commercial buildings meet dec...
