Watts has announced its “Fast Track to Labor Savings” eLearning campaign with dozens of bite-sized modules on Watts Works Online (many available in Spanish and French), d...
Dearborn®, a part of the Oatey family of brands, today announced the addition of True Blue® FLEX to its True Blue Bath Waste line. True Blue FLEX features flexible and adjustable tubing that serves as an alternative to rigid PVC, making it easier to overcome residential and commercial jobsite obstructions such as floor joists, misaligned/offset drains and severely sloped walls.
Innovative, flexible and designed with the plumber in mind, the True Blue Bath Waste line is made with integrated locking features that reduce the number of tools needed for installation, saving time and frustration. Built with the most flexible tubing in the market, True Blue FLEX features a forgiving structure that allows for easier alignment and reduces the number of additional fittings and solvent welded joints needed for offsetting.
True Blue FLEX is available in 16’’ and 24’’ lengths for Standard and Whirlpool tub depths. Additionally, True Blue FLEX is available in Full and Rough kits with Toe Touch, Uni-Lift or Push N’ Pull stopper options, which include chrome, brushed nickel and oil rubbed bronze finishes. It can also be purchased with Direct Drain Fitting to install a P-Trap directly below a bath drain.
Bradford White Corporation, an industry-leading manufacturer of water heaters, boilers and storage tanks, will highlight its latest commercial offerings at the Mechanical...
Rinnai’s RCW Series commercial boilers are delivering sustained, high efficiency water heating performance at 2150 Condos in Toronto, marking the first installation of th...
