Watts has announced its “Fast Track to Labor Savings” eLearning campaign with dozens of bite-sized modules on Watts Works Online (many available in Spanish and French), d...
EVAPCO’s AT Atlas counterflow cooling towers are designed in large, preassembled modules for ease of rigging and installation. As the most energy efficient modular cooling tower on the market, the AT Atlas is unmatched in CTI-certified capacity per cell.
The Atlas’ modular concept and superior performance are ideally suited to projects at or above 4,000 tons. Atlas systems require fewer cells to achieve high cooling capacities, reducing the need for piping and electrical connections by up to 50%.
Atlas series cooling towers range in capacity from 1,484 to 2,386 nominal tons per cell – providing up to 60% more cooling capacity per cell, while requiring up to 40% less fan power per ton of cooling – when compared to traditional factory assembled cooling towers.
Available in Type 304 or Type 316 stainless steel – including the entire basin, support structure, vertical columns, louver frames and plenum. Site installation supervision is available from factory-trained technicians.
Bradford White Corporation, an industry-leading manufacturer of water heaters, boilers and storage tanks, will highlight its latest commercial offerings at the Mechanical...
Rinnai’s RCW Series commercial boilers are delivering sustained, high efficiency water heating performance at 2150 Condos in Toronto, marking the first installation of th...
