Quilt announced the launch of its 3-zone outdoor unit — the most efficient 3-zone ductless heat pump on the market. With a SEER2 rating of 25.3 and HSPF2 (Region IV) rati...
The Mascot FT by Laars is a condensing combi boiler and water heater offering an Energy Star “Most Efficient” qualified rating of 95% AFUE. The system features a robust fire tube heat exchanger and is fully modulating to save fuel.
The natural gas or LP-fired unit is offered in many sizes and configurations: 120, 140, and 199 MBH combi boiler and water heater, or as an 80, 100, 120, 140, and 199 MBH heating only boiler. Combi models include an integrated mini-indirect tank resulting in superior DHW performance by minimizing temperature fluctuations and providing endless hot water quickly.
The integrated mini-indirect tank is always kept charged with hot water. When domestic hot water begins to be used the boiler fires and immediately begins to produce more hot water.
Packed with features, the Mascot FT can be ordered as a floor standing or wall hung unit, includes an easy-to-use advanced control system, a conformal encapsulated control board protected from moisture, gas leak detection system that will shut down the boiler if gas leak is detected for added safety, outdoor reset, domestic hot water priority, primeless condensate trap, zero clearance installation and venting up to 100 feet.
Bradford White Corporation, an industry-leading manufacturer of water heaters, boilers and storage tanks, announces that the company and its business units will exhibit a...
U.S. Boiler Company has expanded and improved its line of Citadel condensing boilers and volume water heaters. The Citadel is now available in seven capacities from 399 t...
