Quilt announced the launch of its 3-zone outdoor unit — the most efficient 3-zone ductless heat pump on the market. With a SEER2 rating of 25.3 and HSPF2 (Region IV) rati...
Modine’s geothermal and water-sourced heat pump systems have earned the trusted AHRI Certified™ mark, an assurance of the product’s performance.
AHRI certification of HVACR equipment is a demonstration of objective, trusted third-party performance. Certified products undergo rigorous, independent annual evaluation to ensure that they perform according to the manufacturers’ published claims – allowing end-users to compare products objectively.
Modine’s geothermal and water-sourced heat pump systems now also offer an enhanced control platform. The robust controller has served the manufacturer’s school systems and commercial ventilation product lines for more than a decade. All of the systems – from 1.5 tons to 12 tons – now feature the proven Modine Control System, providing quick start-up, easy safety device wiring, multiple inputs and outputs, BACnet IP/Eth, BACnet MSTP and Lon capability and easy troubleshooting.
The ENERGY STAR-rated residential and light commercial geothermal product line includes water-to-water, water-to-air, and split unit/air-handling systems; all use R410A refrigerant.
Standard features include ECM fan motors, scroll compressors (dual speed on most units), MERV 13 air filters, oversized heat exchangers and a 10-year limited warranty.
Modine offers a number of options including a desuperheater to provide supplemental domestic hot water; cupronickel heat exchangers for applications where harsh water conditions exist; tin-plated coils to eliminate formicary corrosion; and electric heating for auxiliary back-up heat.
Bradford White Corporation, an industry-leading manufacturer of water heaters, boilers and storage tanks, announces that the company and its business units will exhibit a...
U.S. Boiler Company has expanded and improved its line of Citadel condensing boilers and volume water heaters. The Citadel is now available in seven capacities from 399 t...
