U.S. Boiler Company announces the national availability of its Alliance™ SST stainless steel indirect water heater, offering contractors a durable domestic hot water solu...
Navien, Inc., the number one brand in high efficiency condensing combi-boilers and wall-hung boilers in North America, has started shipping their new lines of fire tube boilers and combi-boilers. The NFB-H condensing fire tube boilers and NFC-H condensing fire tube combi-boilers were first introduced by Navien during their Boiler Virtual Launch Event on February 16, 2021.
Navien’s upgraded NFB-H high-output condensing fire tube boilers are available in two sizes, NFB-175H and NFB-200H. Both models include Navien’s patented stainless steel fire tube heat exchanger with a non-metallic condensate drain pan. The combustion chamber is form pressed to resist corrosion and the heat exchanger is robotic laser welded to ensure the highest quality with repeated results. New high-efficiency features on the NFB-H include turndown ratios up to 15:1, powered connections for 3 zone pumps or 3 zone reduce areas valves, easy to use Setup Wizard for improved installation, 2" venting up to 65' and 3" venting up to 150'.
NFC-H high-output condensing fire tube combi-boilers are also available in two models, NFC-250/175H and NFC-250/200H. The NFC-H also offers Navien’s patented stainless steel fire tube heat exchanger along with a built-in DHW module that includes a flat plate heat exchanger. New advanced features on the NFC-H include turndown ratios up to 15:1, powered connections for 3 zone pumps or 3 zone valves, easy to use Setup Wizard for improved installation, 2" venting up to 65' and 3" venting up to 150'. The NFC-H also includes increased DHW performance with up to 210,000 BTU/H for DHW, offering up to 5.4 GPM at a 70-degree temperature rise.
For more information on both the NFB-H and NFC-H fire tube products visit navieninc.com.
Quilt today launched Toolbox, a dedicated app experience for HVAC professionals who have long been underserved by software built around the product rather than the people...
Quilt today announced it has reached 100 Quilt Certified Partners across 26 U.S. states and six Canadian provinces in under one year since launching its Certified Partner...
