Taco Hydroflo Pump Solutions, a leading manufacturer of large vertical and submersible pumps and skid packages, announced today that its Lubbock facility has achieved ISO...
When using the AUTOADAPT mode, average run times are only 3 hours per day, yielding up to an 85 percent power and 48 percent heat/energy savings over conventional constant-speed circulators.
The single phase, 115V pump motor yields up to 6.5 GPM and uses two temperature sensors; one within the pump and another connected by a cable installed in the hot-water flow pipe.
Grundfos is the only manufacturer to offer a variable-speed electronically commutated motor (ECM)-based circulator that uses an integrated logic algorithm to “learn” the varying energy-usage patterns of an application over time, enabling the software to automatically determine the lowest possible operating‐ efficiency point to meet ever-changing demand. By continuously fine‐tuning power consumption and flow rates to meet the dynamic needs of the system, this AUTOADAPT function saves both energy and money.
The AUTOADAPT function is so powerful that eight out of every ten installations can rely on this feature to automatically select the optimal setting, with no additional human intervention. For the installer, that simply means plug and play and walk away.
For technical details, visit www.grundfos.us/comfortpm
Castrads, the leading manufacturer of premium cast iron radiators, has announced the opening of a new 8,000 sq ft warehouse facility on Robins Lane in Syosset, Long Islan...
Taco is committed to delivering innovative solutions that help our customers achieve the highest levels of efficiency and reliability. That’s why they developed PF Series...
