Surface Igniter, LLC,. a global innovator in hot surface ignition technologies, is proud to highlight the Lennox 70W16 Replacement. This 120 Volt Silicon Nitride Igniter,...
Webstone®, a brand of NIBCO, introduces the new Thermostatic Mixing Valve for high-temperature solar heat sources. This new valve accepts outputs up to 230° from heat source, then mixes with cold water supply to achieve temperatures for the desired application. Optional high-temperature in-line check inserts are also available. Choose from dezincification-resistant end connection fittings in FIP, MIP, SWT, or Press; in sizes ½”-1”. The valve features lead-free, forged brass construction and a temperature-locking handle. Wide array of G1 union fittings, accessories, and isolation kits offer a solution for most installation needs.
Learn more: www.webstonevalves.com/tmv
Founded in 1954, Webstone now operates as a brand of NIBCO and is recognized as an industry leader for innovative design of residential and commercial valves used in plumbing, hydronic, radiant, solar and geothermal applications. These designs focus on time and space-saving concepts that simplify future maintenance and upkeep of all piping systems. Some of the Webstone trademarked and patented items include: Hydro-Core™, The Isolator®, Isolator® EXP Pro-Connect™, and Pro-Pal® step-saving valves.
U.S. Boiler Company, a subsidiary of Burnham Holdings and a key American manufacturer of high-efficiency heating equipment, recently celebrated the opening of its new Con...
Watts has announced its Q4 training focus on “Labor Saving Drains,” with courses designed to equip contractors with the technical expertise and product knowledge needed t...
