Infinitum, creator of the sustainable air-core motor, today announced it will showcase its largest collection of new, high-efficiency HVAC motor systems, partner air hand...
New Water Heater Tempering Valve
The Webstone Water Heater Tempering valve mixes cold water from the supply with the hot output from the heater for greater effective hot water storage. This allows water to be stored at 140°F - mitigating the risk of Legionella bacteria in the tank. Adjustable temperature control limits output to 120°F and prevents the risk of scalding. Installation kits include the lead free valve, temperature gauge and (2) ProPush™ flexible connectors for easy integration with the rest of the system. GUARANTEED FOR LIFE.
Founded in 1954, Webstone now operates as a brand of NIBCO and is recognized as an industry leader for innovative design of residential and commercial valves used in plumbing, hydronic, radiant, solar and geothermal applications. These designs focus on time and space saving concepts that simplify future maintenance and upkeep of all piping systems. Some of the Webstone trademarked and patented items include; Hydro-Core™, The Isolator®, Isolator EXP™, Pro-Connect™, and Pro-Pal® step-saving valves.
Carlin Combustion Technology, a leader in the production of burners, controls and ignitors for residential and commercial heating, and Hydrolevel Company, the leading man...
Armstrong Fluid Technology has expanded its family of new Constant Speed Vertical-In-Line Fire Pumps with a maximum 500 USGPM flow for both 60hz and 50hz markets and feat...
