NIBCO INC. introduces additional configurations of its 585HP (High Performance) Bronze Ball Valves line. The original 585HP line was introduced earlier this year, representing a giant leap in innovation in the ball valve market. Designed for commercial and industrial applications, the lead-free 585HP ball valve line allows for easier installation, adjustability, and long service life.
New configurations in this phase include thread x press end connections for sizes ½” - 2” and hose cap and chain for sizes ½” & ¾” for solder, press, and threaded end connections. All 585HP valves are North American-made and have the following listings and certifications: MSS-SP110/145; IAPMO/ANSI Z1157; NSF/ANSI/CAN 61-8 Commercial Hot 180° F; NSF/ANSI 372; ICC-ES PMG-1558 and ASME A112.4.14/CSA B125.14.
The new configurations feature the same evolutionary design as the original 585HP including the patented laser-welded construction which eliminates the threaded body to body-end connection allowing for a higher operating pressure up to 1,000 CWP and 150 SWP, and operating temperature up to 250° F.
The patent-pending top works features an easily reversible handle providing flexibility for on-site modifications, large accessible packing nut, and triple-sealed stem. These elements combine to make a valve that is easy to install, durable, and dependable all backed by a 10-year, 125 percent limited warranty.
