Watts has announced its “Fast Track to Labor Savings” eLearning campaign with dozens of bite-sized modules on Watts Works Online (many available in Spanish and French), d...
Power-Flow Pumps & Systems; Mansfield Ohio, announces a major expansion to its product offering. In addition to its existing offering of sewage, commercial pond, grinder, cutter and de-watering pumps & controls 1HP thru 50HP, Power-Flo his proud to announce the introduction of; Wet Rotor Circulators (Cast Iron, Bronze & Stainless) 1/25HP thru 1/2HP, Hydronic Expansion Tanks 2 gallon, 4 gallon & 8 gallon, Potable Thermal Expansion Tanks 2 gallon & 4 gallon, Ductile Iron Circulator Flanges, Bronze Isolation Flanges, Residential Sump & Sewage Pumps 1/4HP thru 3/4HP, Base Mounted End Suction Pumps 1.5” thru 20”, Frame Mounted Close Coupled End Suction Pumps 1.25” thru 4”, Horizontal Split Case Pumps 2” thru 16”, standard configuration OR custom designed UL Certified VFD’s and Control Packages FOR ALL of our pump products. Mark D’Agostino; Vice President of Sales & Marketing commented “Though it has been a great deal of work, I am very excited to see Power-Flo Pumps expand to become a formidable player in the US pump & control market. We are certainly earning our new brand pledge- Power-Flo Pumps, Your Power-Ful New Partner For All Of Your Pumping Needs”. For more information, contact Mr. D’Agostino.
Bradford White Corporation, an industry-leading manufacturer of water heaters, boilers and storage tanks, will highlight its latest commercial offerings at the Mechanical...
Rinnai’s RCW Series commercial boilers are delivering sustained, high efficiency water heating performance at 2150 Condos in Toronto, marking the first installation of th...
