Simple Scald Protection with SinkMixer™ 4-Way Thermostatic Mixing Valve
Caleffi North America, Inc. is proud to introduce an all-new, innovative, 4-port scald protection valve for point-of-use applications, the 5212 Series SinkMixer™. Its compact design minimizes connection points by allowing direct connection from the valve to the cold fixture port without the use of an additional tee that is required with 3-port valve configurations. SinkMixer includes a stand-off mounting bracket and standard 3/8” compression connections that easily fit common under-sink hoses and pipe fittings to simplify installation. The precision engineered, DZR low-lead brass body complies with IPC, IRC, UPC and NPC plumbing codes and is NSF/ANSI 372 low lead and ASSE 1070/CSA B125.3 certified.
"The quality and precision of the SinkMixer is a great example of Caleffi’s attention to detail in design and manufacturing," said Kevin Freidt, director of product management and technical support.
SinkMixer will be on display at Booth 6581 during the upcoming AHR Expo in Orlando, Feb. 3-5, 2020. Please contact us at [email protected] or (414) 238-2360 for more information.
Armstrong Fluid Technology marked its 90th anniversary this April, celebrating a significant milestone of longevity and innovation in the fluid-flow systems industry. Sin...
Taco Comfort Solution’s new and improved fully integrated domestic water booster systems are the ideal pressure boosting solution for multi-residential and commercial bui...
