Watts has announced its “Fast Track to Labor Savings” eLearning campaign with dozens of bite-sized modules on Watts Works Online (many available in Spanish and French), d...
Taco Comfort Solutions’® VT Series vertical turbine pumps provide the ultimate in reliability and ease of installation. With six-inch to 18-inch bowl diameters, the VT Series provides quiet, dependable performance for cooling tower, chilled water, water transfer, pressure boosting and water supply applications.
The Taco VT Series vertical turbine pumps offer upgraded materials of construction as standard features. All impellers are investment cast stainless steel to provide longer life and better abrasive and corrosive resistance. All bowls and discharge heads are ductile iron for higher hanging weight and better tensile strength.
For more information, visit www.TacoComfort.com
Bradford White Corporation, an industry-leading manufacturer of water heaters, boilers and storage tanks, will highlight its latest commercial offerings at the Mechanical...
Rinnai’s RCW Series commercial boilers are delivering sustained, high efficiency water heating performance at 2150 Condos in Toronto, marking the first installation of th...
