Rapid Locking System (RLS), the leading provider of press-to-connect fittings and the HVAC/R industry’s most trusted brand, announced the arrival of the new RLS Powered b...
The course explains how electric underfloor heating works and offers guidance on how to select and design a system for residential and commercial projects. Geared towards architects, designers and specifying engineers, the course highlights how electric underfloor heating can be used as a primary heat source in a room, or in the entire dwelling. Warmup monitors 11 homes worldwide, entirely heated with radiant systems as part of its Post-Occupancy research project.
With over 15 years of experience, AEC Daily is one of the largest sources of FREE continuing education courses for architects, engineers, contractors and other construction professionals. The Warmup Inc. continuing education course, Design Flexibility and Efficient Thermal Comfort with Electric Underfloor Heating is now live on AEC Daily’s Online Learning Center (OLC). You may view the course here https://aecdai.ly/warmup.
“Education is essential for our category” says Regis Verliefde, Warmup Territory Director. “It is easy to convince consumers of the luxury of bathroom floor heat, but it is another matter to help the specifying community design an entire space with heated floors as a primary heat source. It is our specialty and we look forward to connect with architects and designers through AEC Daily.”
Warmup’s course provides CEU credits with the AIA, NKBA, NARI, NAHB and IDCEC. It also qualifies as a green course under the USGBC program.
SFA SANIFLO USA, a division of Group SFA and a leading global manufacturer of above-the-floor macerators, grinders, drain pumps, lift stations, and condensate pumps, has ...
U.S. Boiler Company introduces its ALTA OneVent System, a simple and safe solution that enables common venting of up to four ALTA high-efficiency boilers. Designed to exp...
