Watts has introduced the Dead Level Brickslot Grate, a stainless steel slot drain option available for all 6”-wide Dead Level Systems – Ductile Iron Frame (D), Polypropylene Frame (P), and Shallow Channel (S) for cast-in-place applications.
This Brickslot Grate is the ideal solution for jobs that require an equipment- or pedestrian-friendly slope to a finished grade for use with brick pavers or concrete. Its sleek look is designed to fade into the pavement and complement the architectural design of the surface, while efficiently draining walkways and working areas.
It is manufactured to be ADA-compliant and handle loads up to the DIN 19580 Class A classification. For more information, visit www.watts.com.
