Rapid Locking System (RLS), the leading provider of press-to-connect fittings and the HVAC/R industry’s most trusted brand, announced the arrival of the new RLS Powered b...
Armstrong Fluid Technology announced that its recently introduced line of Design Envelope Generation 5 pumps now meet the IE5 efficiency standard for motors. This includes the new Design Envelope Tango™ parallel pumps and Design Envelope Vertical In-Line pumps up to 10hp.
“Design Envelope Generation 5 pumps with iECM™ motor technology deliver both the lowest installed cost and unmatched efficiency over the operating life of the pump.” said Neil Cooper, Armstrong’s Director, Global Sales Enablement. “Meeting the IE5 efficiency standard represents a 20% reduction in motor energy losses from IE4.”
Armstrong Design Envelope pumps were already operating well above established North American efficiency standards. The new Generation 5 iECM motor technology also meets the more stringent IE5 efficiency standards for European markets.
Photo Caption:
Armstrong Fluid Technology announced that its recently introduced line of Generation 5 pumps, including Tango™ parallel pumps above, now meet the IE5 efficiency standard for motors. The new models can deliver up to 96.6% motor efficiency.
About Armstrong Fluid Technology
With over 1000 employees worldwide, operating seven manufacturing facilities on three continents, Armstrong Fluid Technology is known around the world as a forerunner and innovator in the design, engineering and manufacturing of intelligent fluid flow equipment. With its expertise in fluid dynamics, heat transfer, variable speed, and demand-based control, Armstrong Fluid Technology leads the fluid systems industry, including HVAC, plumbing, and fire safety in providing the most energy efficient and cost effective solutions to building professionals and owners around the globe.
SFA SANIFLO USA, a division of Group SFA and a leading global manufacturer of above-the-floor macerators, grinders, drain pumps, lift stations, and condensate pumps, has ...
U.S. Boiler Company introduces its ALTA OneVent System, a simple and safe solution that enables common venting of up to four ALTA high-efficiency boilers. Designed to exp...
