Taco has introduced new, compact HS Series Horizontal Split Case Pumps, which take up 50% less floor space while offering the same superior hydraulic performance. Precisi...
Armstrong Fluid Technology has announced the release of its new Integrated Pumping System (IPS 4000), an automation solution for commercial HVAC pumping stations of up to 8 pumps and 16 zones.
The new IPS 4000:
Pre-configured to leverage the capabilities of Design Envelope, the technology embedded in Armstrong pumps, the new IPS 4000 offers fast and simple setup for the most cost-effective and efficient pump control results. The IPS 4000 is compatible with existing building automation systems and ships pre-programmed for easy installation and set-up.
Commenting on the value provided by the new IPS 4000, Peter Thomsen, Director, Building Systems Solutions, stated, “The new IPS 4000 is a great control and automation solution. In particular, it will add value in any building that has short peak loads or that needs a hybrid solution to provide both Sensorless staging and critical zone sensors.”
Navien, a leading manufacturer of high-efficiency comfort solutions, has announced the launch of its new NAA Series air conditioner, further strengthening the company’s r...
Merino Energy, a San Francisco-based climate hardware company built to make buying and installing a heat pump as efficient as the technology itself, today emerged from st...
