Taco has introduced PS/PA Plate & Frame heat exchangers, custom designed and assembled to specification. They are available in a broad range of connection sizes, 1 inch to 20 inches with a wide range of materials to fit various applications. These heat exchangers are designed, constructed, and tested to meet ASME Section VIII, Div. 1 requirements.
The ASME certified heat exchangers offer standard working pressures/design temperatures of 150 or 300 PSI and 284°F, with higher working pressure and design temperature limits available upon request. The PS/PA Plate & Frame line provides a high degree of flexibility in materials, including the availability of corrosion-resistant 304/316 stainless steel and titanium heat transfer plates, allowing specifiers to meet varying application requirements.
Taco PS/PA heat exchangers are built to handle an almost limitless capacity, meeting or exceeding the most demanding heat requirements in the industry.
