Taco has introduced new, compact HS Series Horizontal Split Case Pumps, which take up 50% less floor space while offering the same superior hydraulic performance. Precisi...
for both lines of their Energy Star®-qualified high efficiency, floor-mounted mini-split heat pump systems with heating that operates at ambient temperatures as low as -15°F (RLFFH line), or -5°F (RLFF line). Efficiency ratings are as high as 26 SEER.
The small indoor units were developed specifically for residential and light commercial retrofit applications, ideally to replace standing radiators or any space with limited upper wall space like a kitchen or sunroom. They are less than 24” high and 30” wide.
Systems are available in 9, 12 or 15,000 BTU single-zone models or in multi-zone configurations. Heating capacity at low outdoor temperatures is achieved through the use of a large heat exchanger and a high-capacity compressor.
For literature, either go to www.fujitsugeneral.com or call your local distributor.
Navien, a leading manufacturer of high-efficiency comfort solutions, has announced the launch of its new NAA Series air conditioner, further strengthening the company’s r...
Merino Energy, a San Francisco-based climate hardware company built to make buying and installing a heat pump as efficient as the technology itself, today emerged from st...
