Rapid Locking System (RLS), the leading provider of press-to-connect fittings and the HVAC/R industry’s most trusted brand, announced the arrival of the new RLS Powered b...
Warmup prides itself in providing the best products and services. When it comes to installation, through customer feedback and testing from its Research & Development Centre, Warmup is constantly looking at ways to improve its products. This is based on the knowledge that time is money and trade professionals are always on the look-out for a better, more efficient way to install underfloor heating.
The StickyMat enables a smaller contractor to install underfloor heating as fast as a larger company. In an internal testing environment, when using StickyMat against a similar product without pressure sensitive adhesive, the installation of StickyMat was 35% faster – a big difference!
StickyMat underfloor heating is more than just a standard heating mat; it is 3ft wide (various lengths available) and it uses a 1/8” pre-paced wire with tough fluoropolymer coatings which provide inner and outer insulation for even surface heat distribution. The StickyMat is suitable for all projects: new build and renovations. Once installed you have two options: lay a thin, self-levelling thin set over the mat and leave it to dry OR trowel a full bed of flexible tile adhesive directly over the mat and lay the floor tiles.
Although the installation process is simple, we're with you every step of the way. Warmup offers a market leading 24/7/365 technical support service to give personal advice during and after installation.
In line with Warmup’s tradition of offering the best warranties and guarantees, StickyMat comes with a 30-Year Warranty and SafetyNetTM Installation Guarantee. This means if you accidentally damage the system during installation, Warmup will replace it free of charge!
To receive more information or a quotation, please contact Warmup
T: (888) 927 6333, email, or visit www.warmup.com
SFA SANIFLO USA, a division of Group SFA and a leading global manufacturer of above-the-floor macerators, grinders, drain pumps, lift stations, and condensate pumps, has ...
U.S. Boiler Company introduces its ALTA OneVent System, a simple and safe solution that enables common venting of up to four ALTA high-efficiency boilers. Designed to exp...
