Quilt today announced it has reached 100 Quilt Certified Partners across 26 U.S. states and six Canadian provinces in under one year since launching its Certified Partner...
All Laars commercial NeoTherm boilers now come with a large color touch screen as standard equipment.
The easy to navigate color touch screen allows for quick access to the control’s full functionality in a user friendly interface. A new variable speed boiler pump control option, VARI-PRIME™, is also available that optimizes total installed efficiency by matching boiler input modulation to pump flow.
The fully packaged, 95% efficient commercial NeoTherm line is available from 285 through 1,200 MBH sizes as a modulating boiler or volume water heater.
NeoTherm is a direct vent, sealed combustion boiler or volume water heater that modulates with a 5 to 1 turndown (10:1 for 1,000 and 1,200 sizes). Zero clearance to combustibles and consolidated connections (horizontal or vertical direct vent) make it an excellent choice for tight installations.
All NeoTherms include the Laars’ Integrated Control System with PID logic that governs ignition, outlet water temperature, indirect water heater functions, outdoor reset, stages up to 8 boilers with the standard control, and easily integrates with other controls for multiple boiler sequencing and building automation systems.
Zero clearance to combustibles make it a good choice for tight installations. The natural gas or LP-fired boiler features an ASME stainless steel heat exchanger and low 10-ppm NOx emissions. Advanced features include full diagnostics and a pull-out electrical panel for easy access.
For more information, or a list of suppliers, please visit www.Laars.com.
Rinnai America Corporation, a leading North American manufacturer of innovative, energy‑efficient tankless water heaters, today announced its REHP Series Electric Heat Pu...
New Taco Thermal Energy Storage (TES) tanks play a critical role in shifting energy loads, improving hydronic system efficiency, and helping commercial buildings meet dec...
