Taco has introduced new, compact HS Series Horizontal Split Case Pumps, which take up 50% less floor space while offering the same superior hydraulic performance. Precisi...
Modine’s geothermal and water-sourced heat pump systems have earned the trusted AHRI Certified™ mark, an assurance of the product’s performance.
AHRI certification of HVACR equipment is a demonstration of objective, trusted third-party performance. Certified products undergo rigorous, independent annual evaluation to ensure that they perform according to the manufacturers’ published claims – allowing end-users to compare products objectively.
Modine’s geothermal and water-sourced heat pump systems now also offer an enhanced control platform. The robust controller has served the manufacturer’s school systems and commercial ventilation product lines for more than a decade. All of the systems – from 1.5 tons to 12 tons – now feature the proven Modine Control System, providing quick start-up, easy safety device wiring, multiple inputs and outputs, BACnet IP/Eth, BACnet MSTP and Lon capability and easy troubleshooting.
The ENERGY STAR-rated residential and light commercial geothermal product line includes water-to-water, water-to-air, and split unit/air-handling systems; all use R410A refrigerant.
Standard features include ECM fan motors, scroll compressors (dual speed on most units), MERV 13 air filters, oversized heat exchangers and a 10-year limited warranty.
Modine offers a number of options including a desuperheater to provide supplemental domestic hot water; cupronickel heat exchangers for applications where harsh water conditions exist; tin-plated coils to eliminate formicary corrosion; and electric heating for auxiliary back-up heat.
Navien, a leading manufacturer of high-efficiency comfort solutions, has announced the launch of its new NAA Series air conditioner, further strengthening the company’s r...
Merino Energy, a San Francisco-based climate hardware company built to make buying and installing a heat pump as efficient as the technology itself, today emerged from st...
