Watts has announced its “Fast Track to Labor Savings” eLearning campaign with dozens of bite-sized modules on Watts Works Online (many available in Spanish and French), d...
Navien, Inc., the number one brand in high efficiency condensing tankless water heaters, has launched the brand new NPE-2 series. Navien NPE-2 series is the biggest update to condensing tankless water heaters in North America since the NPE series changed the landscape of the industry in 2012. The NPE-2 is offered in four Standard (NPE-S2) models up to 199,900 BTU/H and three Advanced (NPE-A2) models up to 199,900 BTU/H.
Advanced innovation engineered into the NPE-2 allows for new high-efficiency features and technology including a turndown ratio up to 15:1, EZNav™ advanced multi-line control with built-in intuitive software and easy-to-use Setup Wizard, increased 2” PVC venting length up to 75-feet, vent installation detector, built-in HotButton™ on-demand system controls, expanded cascade capability up to 32 units and expanded common venting capability up to 12 units.
The NPE-2 will continue to offer the features that made the NPE the number one selling condensing tankless water heater in North America, such as dual stainless steel heat exchangers, half-inch gas pipe capability up to 24 feet and ComfortFlow™ recirculation system with built-in recirculation pump and buffer tank on the NPE-A2.
Navien’s NPE-2 will continue to support popular Navien accessories for enhanced installations including NaviLink® Wi-Fi remote control system, NaviCirc® recirculation crossover valve, H2Air® for combination space heating and domestic hot water system, and ReadyLink® manifold system for simplifying multi-unit installations on walls or racks.
Bradford White Corporation, an industry-leading manufacturer of water heaters, boilers and storage tanks, will highlight its latest commercial offerings at the Mechanical...
Rinnai’s RCW Series commercial boilers are delivering sustained, high efficiency water heating performance at 2150 Condos in Toronto, marking the first installation of th...
