Watts has announced its “Fast Track to Labor Savings” eLearning campaign with dozens of bite-sized modules on Watts Works Online (many available in Spanish and French), d...
Navien introduces NaviClean™, Powered by Adey®, the highly recommended magnetic boiler filter designed to work with Navien NHB boilers, NCB-E combi-boilers and any other boiler system up to 199,000 BTU/H. NaviClean protects boiler systems by using a powerful permanent magnet to capture high levels of iron oxide, sludge and debris from the incoming water lines.
NaviClean is designed with bi-directional flow and 360 degree rotational valves, making in-line installations simple enough to be completed in just two minutes. The quick-release trigger and rapid-fit connectors also allow for quick maintenance and reinstallation.
The dirt filtration technology of NaviClean helps extend the life of a hydronic heating system while reducing heating costs, maintenance costs and carbon emissions. NaviClean is available now at your nearest Navien wholesale distributor.
Bradford White Corporation, an industry-leading manufacturer of water heaters, boilers and storage tanks, will highlight its latest commercial offerings at the Mechanical...
Rinnai’s RCW Series commercial boilers are delivering sustained, high efficiency water heating performance at 2150 Condos in Toronto, marking the first installation of th...
