The Duravent Group™—a recognized leader in the venting and air control industries and trusted partner to HVAC professionals—returns to the 2026 AHR Expo from February 2-4...
Navien’s Water Saver
Navien’s NPE-A series innovative ComfortFlow® technology incorporates a built-in buffer tank and recirculation pump inside the unit to provide a zero GPM activation rate. Additionally, with the ComfortFlow buffer tank, the “cold water sandwich”, common in other tankless units, is eliminated. With a return line, the pump saves thousands of gallons of water per year. Additional Navien NPE standard features include: dual stainless steel heat exchangers, 1/2” gas lines up to 24’ and 2” PVC venting up to 60’. These technical advances make the NPE-A series ideal for commercial and residential tank water heater replacement as well as new construction. Navien.com
About Navien
An official ENERGY STAR® partner of the Residential Water Heater Program, Navien is the recognized leader in condensing technology and combination gas boilers. Navien products are available in the United States and Canada through a selected network of wholesale distributors. For more information visit us at Navien.com
Armstrong Fluid Technology, a global leader in intelligent, energy-saving fluid-flow and whole-building mechanical solutions, has named Chintan Kharche as Global Director...
Surface Igniter, LLC, a global innovator in hot surface ignition technologies, is proud to highlight the Lennox 70W16 Replacement. This 120 Volt Silicon Nitride Igniter, ...
