Taco has introduced new, compact HS Series Horizontal Split Case Pumps, which take up 50% less floor space while offering the same superior hydraulic performance. Precisi...
Webstone®, a brand of NIBCO, announces two new y-strainer products. The patent-pending Pro-Pal® Ball Drain Strainer™ is available in sizes ½” to 1 ¼”. It features a multi-function hi-flow hose drain with an integrated y-strainer, ideal for diverting fluid into the drain from either side of the ball and isolating the strainer from upstream flow for service. Also available is the new y-strainer in sizes ½” to 2”. Both products are available in press or FIP and feature lead-free dezincification resistant forged brass construction, replaceable 20 mesh screens, and O-ring sealed and plugged strainer port for easy removal of the filter and installation of the drain valve.
Learn more at www.webstonevalves.com/pro-pal
Founded in 1954, Webstone now operates as a brand of NIBCO and is recognized as an industry leader for innovative design of residential and commercial valves used in plumbing, hydronic, radiant, solar and geothermal applications. These designs focus on time and space-saving concepts that simplify future maintenance and upkeep of all piping systems. Some of the Webstone trademarked and patented items include: Hydro-Core®, The Isolator®, E-X-P®, Pro-Connect™, and Pro-Pal® step-saving valves.
Navien, a leading manufacturer of high-efficiency comfort solutions, has announced the launch of its new NAA Series air conditioner, further strengthening the company’s r...
Merino Energy, a San Francisco-based climate hardware company built to make buying and installing a heat pump as efficient as the technology itself, today emerged from st...
