Taco has introduced new, compact HS Series Horizontal Split Case Pumps, which take up 50% less floor space while offering the same superior hydraulic performance. Precisi...
Oatey Co. today announced the launch of the Fix-it Repair Ring™, which securely repairs broken, cracked or worn-out toilet mounting flanges without replacing the toilet flange.
Built with a robust design for installation strength, the Fix-It Repair Ring features a sleek, unobtrusive profile. It’s conveniently compatible with all flange and toilet installations, as well as flooring types (including concrete). Plus, 10 mounting holes and four slotted mounting tabs further enable a wide range of installation options.
The Fix-It Repair Ring is built for installer ease and reliability, including a perfect-length bolt slot that prevents bending during installation and provides secure, level, leak-free repairs. It can accommodate 1/4-inch or 5/16-inch closet bolts. Because of the thicker wall span between the bolt slot and the ring perimeter, weak points are minimized.
Navien, a leading manufacturer of high-efficiency comfort solutions, has announced the launch of its new NAA Series air conditioner, further strengthening the company’s r...
Merino Energy, a San Francisco-based climate hardware company built to make buying and installing a heat pump as efficient as the technology itself, today emerged from st...
