Oatey Co., a leading manufacturer in the plumbing industry since 1916, announced today the launch of its updated Drain Seal, which blocks unwanted odors, sewer gases and insects from entering a building through a drain, featuring an enhanced design that won’t restrict water flow or sacrifice drain performance.
Oatey’s Drain Seal is engineered with a drainage system that not only prevents water from evaporating in the P-Trap, but also allows for continuous water flow, which simultaneously inhibits ponding or pooling around a drain.
The Drain Seal is a non-chemical solution that does not require the use of any tools for installation, making it a safe, convenient way to promote a clean home and protect everyday or infrequently used drains in locations such as showers, basements, garages, wet rooms, utility rooms and laundry rooms. Available in 2’’ or 3’’ sizes, the new design is compatible with most popular floor and shower drains.
